70 Hemi Cuda auto trans cooler lines
Started by GCragtop, July 23, 2022, 11:01:11 AM
GCragtop
Which way the aux cooler lines should be routed on 70 Hemi E-body?
MoparCarGuy
#1
The 1970 Service Manual shows only one diagram. @fc7cuda pointed out this is the 1970 B-Body transmission cooler. The service manual does not have the E-Body auxiliary transmission cooler diagram. The other pics show the cooler. The transmission cooler lines connect directly to the E-Body cooler on the passenger side of the radiator support opening at the bottom.
fc7cuda
#2
Quote from: MoparCarGuy on July 23, 2022, 02:54:28 PM
The 1970 Service Manual shows this diagram.
First pic is a B-body setup, E-body is different.
Do you have the lines and need to know how they're routed?
GCragtop
Thanks for the replies! Lines what I have here are wrong, for B-body. Need to order a correct ones.
