Ahhh Crap!!!!! Bad lifter?
Started by Cudajason, June 02, 2019, 02:24:31 PM
Well crap...this does not sound good.   :pullinghair: :pullinghair:
Pretty sure this is a bad liter...hopefully nothing more serious.
I was able to isolate it to the exhaust on the number 7 cylinder.  I ran it with the valve cover off and put pressure on the rocker arms and it quiets significantly with pressure of the pushrod side of that rocker.
sigh...what this right way to fix this.
https://youtu.be/b0qd83yWWCA
take a magnet & pull the lifter out
nsmall
Oh man.  I hope its something minor.  Best of luck to you.   :fingerscrossed:
Quote from: Chryco Psycho on June 02, 2019, 02:28:05 PM
Harder then it sounds!!!!
Just does not want to come out!!!
The oil creates a bit of suction. Hopefully.
Quote from: RUNCHARGER on June 02, 2019, 04:56:11 PM
Yeah I am hopping that is what it is!!!
My dad used to have a tool that was like a small slide hammer that had a flanged end that locked into the lifter and it was the greatest invention since sliced bread but it's disappeared over the decades. You've got the intake back off?  :huh:
Quote from: RUNCHARGER on June 02, 2019, 05:15:33 PM
Did you look at the oil?
Only on the dipstick...looks fine, does not appear to be any metal in it.
I do not have the intake off yet. I was hoping not to have to take it off.
I s the lifter moving up & down some ?
Quote from: Chryco Psycho on June 02, 2019, 06:15:12 PM
Oh yeah moving up and down with the magnet and spinning. Just wont come all the way out!!
A new lifter should just slide out .
Can you pull the dist & see the lobe ?
Quote from: jimynick on June 02, 2019, 05:22:12 PM
https://www.ebay.ca/itm/Performance-Tool-Hydraulic-Lifter-Removal-Tool-W84004/192897288815?hash=item2ce9930a6f:g:vesAAOSw~TdcwDXJ
If it raises up a bit and then won't come out the rest of the way I don't think that things look good. Sorry.
