avatar_FSHTAIL
Can't find 8 3/4 axle seals/gaskets
Started by FSHTAIL, September 29, 2017, 02:16:36 PM
FSHTAIL
I've gone to four different auto parts stores and none of them can find me axle seals or  the end seal gaskets.
Not in stock, doesn't even give an option to order.
AutoZone, O'Reilly, Napa, and one more Napa..
The rear end I'm using is out of a 65 Dodge Coronet, so I had them look up 65, 66 Dodge Coronet, 70 Cuda, 70 Challenger.
Zero.
I was hoping to get a jump start on this Swap this weekend, but this is a stupid setback. Either these parts aren't available anymore or I have found all of the idiots on the right day.
Please advise.
Picture of seal I want to replace.
And the gaskets needed for that end flange.
Sent from my SM-G930T using Tapatalk
I get mine from MoparDave.  Mancini has them also as well as Doctor Diff.   I doubt you will find or get the correct ones from a local parts store.
Mrbill426
NAPA stocks them, you want the part numbers I will get them for you.
Mrbill426
Oh heck, here you go...
Seals (2)  Napa #15460, or Timken # 8695S
Gasket (2) Felpro #13800
Gasket (2) Felpro #55032
:wrenching:
Quote from: Mrbill426 on September 29, 2017, 02:37:55 PM
Mrbill426
Quote from: Mrbill426 on September 29, 2017, 02:40:05 PM
That is assuming that the flanges are the same as the later 8.75" axles  ;)
:wrenching:
FSHTAIL
:wrenching:
Mrbill.
You're a life saver.
I'll head there in a bit.
Mrbill426
You might call ahead  ;)
Quote from: Chris Pauluk on September 29, 2017, 02:54:19 PM
:wrenching:
Mrbill.
FSHTAIL
They magically found these part numbers, I'm blown away LOL
Mrbill426
 :woohoo:  :cheers:
Quote from: Chris Pauluk on September 29, 2017, 03:28:31 PM
When you are working on something much older than the kid behind the counter, you have to expect that!!!
Mrbill426
Yep, that is what the parts books are for; the ones collecting dust in the back room... if they still even have them.  ::)
Quote from: JS29 on September 30, 2017, 09:53:24 AM
This always comes to my mind when dealing with local parts stores.
Roadman
Quote from: Shane Kelley on September 30, 2017, 03:58:45 PM
               :haha: :haha: :rofl: :rofl:  The best way to deal with parts stores is look up the part # first, then hand it to the parts guy when you walk in. After the deer in the headlights look, you will get your parts. Do your research first.     :alan2cents:             :rebelflag"
dougdel
Quote from: Roadman on September 30, 2017, 05:51:49 PM
150%.  :iagree:
Or place your order at the local parts  ( advance, pep boys, etc) website to try and speed things up and maybe even get a little discount
Convertcuda
MrBill
Do you know the parts for the axle bearings for a 8.75?
Thanks Ken
