avatar_FSHTAIL
Can't find 8 3/4 axle seals/gaskets
Started by FSHTAIL, September 29, 2017, 02:16:36 PM
Mrbill426
If you mean the axle shaft bearing, the set number is a (NAPA) BR7, includes the cup, cone, and retaining ring.
Quote from: Convertcuda on October 03, 2017, 06:13:15 PM
MrBill
Do you know the parts for the axle bearings for a 8.75?
Thanks Ken
Convertcuda
Yes sorry thats what I meant. Thanks!! Do you know the number in Timken?
Thanks Ken
Mrbill426
I think it is just #Set7
NAPA bearings are SKF
Quote from: Convertcuda on October 04, 2017, 04:23:08 AM
Thanks Ken
Convertcuda
Thanks is there a special seal that goes into the retainer?
Mrbill426
The outer seal is NAPA 19000, National 8704S, or Mopar 2404216
The carrier to housing gasket is Felpro RDS6583
Quote from: Convertcuda on October 04, 2017, 06:18:58 PM
Convertcuda
I just want to make sure that I have the right seal. The one I'm referring is the one fits into the bearing retainer adjustment plate. I wanted to buy all Timken from Rock Auto. Thats why I was asking for the numbers. Thanks for the help.
Thanks Ken
Mrbill426
Yes.  I think all those seals are for is to keep the axle bearing grease in and dirt/water out.   The inner seals keep the gear lube from flowing out and getting into the brakes.  The bearings do not run in oil, they are lubed by packed grease.
If I am wrong, someone PLEASE step up and set me straight.  :popcorn:
Quote from: Convertcuda on October 05, 2017, 07:16:56 PM
Thanks Ken
Quote from: Mrbill426 on October 05, 2017, 07:32:16 PM
Thanks Ken
That is correct!
Sounds to me like Mr Bill has spent quite a few years behind a blue & yellow counter....
Mrbill426
 8)  :cheers:
Quote from: 1 Wild R/T on October 06, 2017, 08:56:17 AM
mjb765
