avatar_erik70rt
Front Bearing Retainer Question
Started by erik70rt, October 25, 2024, 06:00:21 PM
erik70rt
Tonight I learned the hard way that my 4 spd transmission has the large bearing retainer on it so it won't bolt up to my 340 bellhousing with the small retainer opening.
My question is can I swap the large retainer on the transmission to  small one? Or do I need a whole new transmission case?
Mr Cuda
If you opt to bore the pilot hole, there is not much meat for the pivot bolts.
I did this one to run an 18 spline.
