avatar_fireguyfire
Incorrect engine ID
Started by fireguyfire, March 22, 2019, 11:05:42 PM
fireguyfire
I have an earlier 383 that came in my 73 challenger that is extremely fast.
I am planning on tracking down a period correct 340 for my car and selling the 383, but for now I would like to know the year of the engine.
Casting number is 2468130.8 which is383.
On the engine ID pad all it has is 0B144335
Am I correct that the 0 is 1970 and the B is Hamtrack?
6bblgt
correct, it is a 383 from a '70 Challenger built at Hamtramck
what is stamped on the pad below the distributor?
aussiemark
How can you tell what type of car from the partial VIN?
He makes an assumption based on other cars he has information on... :twothumbsup: Similar cars were built in batches. :alan2cents:
If it runs great I'd leave it in. They're great for teaching Chevy guys what a real 383 is.
fireguyfire
I'll post up what's on the distributor pad when I can; I've got the car up on my lift right now rebuilding the front end so it might be a day or 2
js27
If it is a HP motor and and early NOV assembly date I would be interested in buying it. But going by the VIN I would say it was a late Sept or early Oct. built car.
JS27
fireguyfire
Sounds good; do I get that information off of the distributor pad?
js27
YES. It will look like this
JS27
fireguyfire
I'm having a hard time finding that number with all of the stuff on the engine in the engine bay.
Can you describe exactly where it is for me?
In front of the cylinder head below the dist behind the water pump housing
js27
Quote from: Chryco Psycho on March 28, 2019, 09:55:15 PM
One picture is worth 1000 words--The alternator hides it.
JS27
fireguyfire
Got a bit of time today and was able to clean up the spot pretty good with a brass brush. Still can't decipher what's on there, I'm guessing I'll have to pull the alternator to clean it up properly to see what's there.
Could have been machined off if the motor was ever decked  :dunno:
js27
Quote from: anlauto on March 29, 2019, 06:51:10 PM
Very possible Alan--do you know if warranty block came stamped with this info-I know they did not have the VIN on them but no sure about the assembly date info.
JS27
