What power train should I go for?
Started by Gizmo327, July 23, 2019, 08:32:06 PM
Purple cams were Mopar cams sold through MP , most were designed back in the 70s , there are btter choices now
Quote from: Chryco Psycho on July 24, 2019, 06:42:35 PM
440 requires a trans swap , small blocks & 3rd gen Hemis do not
3rd gen hemis bolt up to 727's and 833's?
Quote from: dodj on July 29, 2019, 05:39:05 PM
Yes 3rd Gen Hemis use the small block bolt pattern & can bolt to A833 / 727/ 904 / 518 , anything with a small block bolt pattern
Quote from: Chryco Psycho on July 29, 2019, 05:48:00 PM
The bolt pattern is the same, however you will need new bolts for the specific application due to different depths in the block.
