Which model of oil pan valid for my big block 440
Started by THE ZUKE, February 17, 2019, 04:02:42 AM
0 Members and 11 Guests are viewing this topic.
THE ZUKE
Quote from: RUNCHARGER on February 17, 2019, 09:21:03 AM
You can work the dent out with a block of wood and a hammer. However if your current pan has baffles in it, they will have to be cut out and then welded back in to let you do the bodywork. That 440source pan is dirt cheap and won't show signs of being repaired.
It is certain, but if I buy a new part, I prefer choosing the quality part such as copy 971 of Moroso at SUMMIT.
More expensive but probably better
GrandpaKevin
Not sure why you think a Moroso oil pan is such a quality part, I've never been impressed with Moroso's products and Milidon's oil pans are a much higher quality part but are overkill for your application. :alan2cents:
If you dead set on buying from Summit Racing here is the same 6 quart oil pan 440 source sells at Summit.
https://www.summitracing.com/parts/sum-g3511/overview/
I've been using this exact oil pan for the last 3 years and it has worked perfectly...I replaced a beat up, leaking Moroso oil pan with it when I rebuilt the 440 Six Pack engine in my wife's car. My engine builder was very impressed with the fit and finish of the Summit oil pan.
THE ZUKE
Quote from: GrandpaKevin on February 17, 2019, 09:41:30 AM
Okay, I'll listen to what you tell me. ;)
I validate the oil pan you have been using for 3 years.
Having several pieces to order, all at SUMMIT, I will order at home.
For us in France, transport is very expensive, that's why the ideal is to order everything from the same supplier. :dunno:
cuda hunter
Quote from: RUNCHARGER on February 17, 2019, 08:14:19 AM
Yes a 440 E-body is supposed to have a "Hemi" style pan like that 440source one. A 402 pan is smaller than what the factory put on the 440s in an E-body. Also order a windage tray and the matching pickup tube.
I'm sorry for the incorrect number.
I have a 402 on my a body and have had a 402 on an e body.
I didn't realize that was not the stock number for the e body.
I think the 402 is correct for a 383 E-body but I might be wrong on that. The 440's used the big pan and it is a really good idea.
6bblgt
1970-'71 E-body:
383 2bbl, 383 4bbl & 383HP = "402" oil pan
440HP, 440+6, HEMI = "HEMI" oil pan (K-frame also had a "skid" plate to protect the deeper pan)
6bblgt
Quote from: cuda hunter on February 19, 2019, 06:03:15 PM
:thinking: "402" would hit the idler arm in an A-body - the C-body "187" with "idler arm DIVOT" is usually found in a big-block transplant A-body (the big-block A-body pan is currently reproduced)
cuda hunter
Quote from: 6bblgt on February 19, 2019, 08:50:21 PM
Correct.  However My buddy and I did this to the pan back before the internet days. Couldn't find anything that would work so we did this to the pan.  It's still working.
  and this is on a small block K frame as well.
THE ZUKE
No soucy  ;)
THE ZUKE
Quote from: RUNCHARGER on February 19, 2019, 07:14:02 PM
I don't know the difference betwin a 383 and a 440 (about oil pan).  :dunno:
I bet Dave at Roseville would have what you need with a member discount
I remember when Neil recommended the 6 quart BB Milodon pan for my 440.
Think I got it from Mancini's, has worked great and with it painted it looks like it belongs!
:twothumbsup:
I've ordered/used two (the original and first pan got dented through my stupidity) of the 6 quart pans from 440 source and have not problem with them whatsoever.  Good quality and they seal up great. For the price and factory look I don't think you can go wrong with them.
THE ZUKE
News  ;)
I received my new oil pan but I am not sure it's the good model (Summit model or 440 source / One of my pictures), I think it's like a 402.
While trying to take ribs (Really not easy with the cuda on jake stand), I'm afraid that the front of the Summit oil pan will not pass to the K-member front.
The width and length appear to be the same on both models (for a 440).
Before painting, I will dismount the old oil pan (971) and try to mount the new one (Summit model).
The front of the 402 is much longer than the 971 (the one currently installed).
I have a cuda 70 with a 73 engine (picture engine number).
