avatar_RazorX
Advice on resto center console panel
Started by RazorX, April 12, 2021, 07:41:43 PM
RazorX
Does anyone have any tips for removing the old wood grain from a 73 challenger floor console plate?
I've got one that I will restore with new wood grain 3M vinyl,  just wondering if anyone has effectively stripped the old vinyl and under lament away?  I was going to try aircraft stripper.  Maybe someone out there has a slick way they could share. , thoughts?  thanks
They are a pain in the arse....I use a heat gun and razor blade scraper :pullinghair:
dylo
PITA? Dammit that's not what i wanted to hear.
I'm about to undertake the exact same task. I was hoping soaking in some thinners or something might soften it?
Cheers,
Dylan
FE5CUDA
Take a heat gun to the bottom of the plate, that way the glue loosens before the sticker curls up and melts.
larry4406
I recall someone posting about using WD-40 to soak under the sticker and dissolve the adhesive and scraping with a plastic putty knife.
Found this link while searching unsuccessfully for the above
https://moparforums.com/forums/f6/removing-wood-grain-center-console-16419/
I used a steam cleaner.  The hot water took off the decal fairly quickly.
RazorX
Heat gun to the underside and various razor blade scrapers ... worked like a charm  :ohyeah:
Thanks all.
Quote from: RazorX on April 13, 2021, 04:36:51 PM
Thanks all.
Told you so, I'm glad it worked out for you  :twothumbsup:
70 Top Banana
Yep, I agree with RazorX, use a heat gun and various scrapers. I used a sharp paint scraper I got from a Sherwood Williams paint store and it worked well
