avatar_anlauto
Curious Brake SIZE question ???
Started by anlauto, March 13, 2023, 02:44:27 PM
Has anybody tried to put a stock Mopar 15 X 7 rally rim over Wilwood 4 piston rear disc brakes ? Or front Wilwood 4 piston or 6 piston front brakes ?
Yeya93
i just ran into this problem myself last month. 4 piston rear and front wilwood. the front fit fine, the rear does not fit rallye wheels. i used wheels vintique 15x8 rear, And 15x7.
i went ahead and used steelies with dog dish instead
Sent from my Pixel 7 Pro using Tapatalk
That's odd, is it not the same size rotor front and back ?
Yeya93
@anlauto it's not. i forgot the exact sizes. but here are the bottom two part numbers that i had purchased. you can download the specs and look into it. but i know rallyes didn't fit the rear.
Alright thank you for that info, I'll look into it a bit more. :cheers:
