Dumb LCA question.
Started by Rdchallenger, July 12, 2019, 05:25:27 PM
Rdchallenger
Quote from: 340challconvert on July 13, 2019, 07:58:47 AM
One other thing to consider; the reinforcement plates that could be added to the bottom of the LCA's. Since they are out of the car; helps with flex for minimal dollars. I am thinking that you will change out the LCA bushings. I bought this kit from Just Suspensions.
They already have the reinforcement plates as well! :bradsthumb:
Rdchallenger
Quote from: Rdchallenger on July 13, 2019, 09:46:25 AM
Quote from: 1 Wild R/T on July 13, 2019, 09:36:01 AM
Quote from: Brads70 on July 12, 2019, 06:29:36 PM
Quote from: RUNCHARGER on July 12, 2019, 06:22:45 PM
Add a big sway bar, you won't believe how much nicer it will drive.
:iagree: but beware.... one thing leads to another!  :yes:
Recommend this one, (I'm using it on mine) but shop around for pricing!
https://www.hotchkis.net/product/front-sport-sway-bar-set-70-74-mopar-e-body-from-hotchkis-sport-suspension/?mk=40&yr=1970&md=286&sm=295
Hotchkiss makes a nice bar but the Hellwig bar is virtually the same with a slightly lower finish quality for half the cost...
So you can have front & rear for less than the cost of just the front from Hotchkiss
https://www.jegs.com/i/Hotchkis/515/2254/10002/-1?&mrkgcl=1239&mrkgadid=3337738013&adpos=1o3&creative=344096037769&device=c&matchtype=&network=g&jegspromo=nonbrand&gclid=CjwKCAjwgqbpBRAREiwAF046JYrFxZDLl14U8kuQt7On0g2VY8lrxQVsOJVoMr7pyn4XRyPHmYMcGBoCZ7IQAvD_BwE&gclsrc=aw.ds
https://www.sdtrucksprings.com/index.php?main_page=product_info&products_id=16955&gclid=CjwKCAjwgqbpBRAREiwAF046JRtbGb-XZrUbw4xGXCpQiFVDH7Ek6cE1wFsq44gn0A_dPgIHuwYt-hoC88UQAvD_BwE
https://www.sdtrucksprings.com/index.php?main_page=product_info&products_id=10103&gclid=CjwKCAjwgqbpBRAREiwAF046JS6ooGyDYeu52qpVYatZV0XMhpzlKzYUO-N4uTSisckI-tRisbXqIBoCQVgQAvD_BwE
I may just go with FF for the bar as well when I order my torsion bars from them. Save on shipping.
The SD Springs link has free shipping....  At least have a look...
Will those larger front sway bars fit through the K-member without issue?
Rdchallenger
Oh damn. In that case I'm all for the SD sway bar and will be adding the rear one as well.
Quote from: Katfish on July 13, 2019, 12:32:07 PM
They fit fine, even with the factory skid plate...
1973Barracuda
I ordered one thru SD years ago. Very happy with that bar on my 73.
temsinc
I installed both front and rear Hellwig on my 70 Barracuda...had no fitment issues. They both installed without any problems and I must say a noticeable difference with handling. Oh, and they look damn sexy  :inlove:
Darcy
Quote from: temsinc on July 13, 2019, 08:22:04 PM
Darcy
If you lay them next to Hotchkiss bars the shape is virtually the same but the ends where the bushings go on the Hellwig are just squeezed a little flat & a hole is punched through....
The Hotchkiss have nice smooth rounded pockets for the end link bushings... They are nicer..
But I've run plenty of bars with the Hellwig style ends & they always work just fine...  I'm keeping the extra money in my pocket...
