avatar_Cudajason
Help Getting Rear Drum Off
Started by Cudajason, June 26, 2022, 06:42:58 PM
Quote from: Brads70 on July 01, 2022, 06:48:55 PM
Jason , if you find you need and axle or what ever? I have my old  8 3/4 still sitting here, your welcome to what ever you need? I did install all new studs in my axles as well. I did use the drum brakes on my Javelin so just the housing and axles are left.
You know Brad, there aren't too many like you and that's a pity. Good on you matey!! :twothumbsup:
Quote from: jimynick on July 01, 2022, 08:25:24 PM
Thats the truth @jimynick I seem to know at least 4 of those guys.
Thanks for the offer @Brads70 I think I am ok right now, but may touch base with you on the rear.
I probably need to do the rear bearings and seals (would like to do a gear change as well), but its tough to do in my little 10x20. I may be interested in what ever you have left if it fits an e-body.
Quote from: blown motor on July 01, 2022, 06:13:51 PM
Yes there should be room without removing the axle. You will have to turn the axle a couple times to get enough room behind them.
Yep agreed you can do it without removing the axles. Easy if you remove the break shoes.
True but not necessary. I just did it in my truck without removing shoes.
Jay Bee
Dakota wants to install longer studs. Just curious if there's a length limit for the studs before the axle has to come out.  :dunno:  :thinking:
There is quite a bit of room to put in longer studs.
Some pics of the spacing...
I bought studs from Summit that were 2.875" long  based on a post Alan made about what he uses. These were too long to fit behind the axle flange plus they were too long for my lug nuts.  I ended up cutting about an inch off them.   They fit fine once shortened.
I bought another set of the same studs for the front wheels (did a disc conversion previously) but haven't put them on yet.
Quote from: Cudajason on July 02, 2022, 12:18:06 PM
You guys make me want to move north of the border.
All alone down here.
