Rear shock psi?
Started by billdogg5, September 03, 2021, 07:17:52 AM
billdogg5
74 challenger with original rear shocks, what air pressure do they take?
Thanks!
Quote74 challenger with original rear shocks
Stock air pressure was NONE.  74 Challengers didn't come with air shocks.
DeathProofCuda
If you have air shocks in the rear of your car, they are not original.  Air shocks on a muscle car are usually used to adjust the stance of the car, so the pressure needed is based on how high you want the raise the rear end.  Just be aware that using air shocks to raise the rear of your car can damage the upper shock mounts.  Your leaf springs are designed to hold up the rear of your car, not your shocks.
They aren't original, but likely added the first time the owner thought the car's butt was sagging.
If it were me I'd replace them with proper shocks.
There is no real good psi setting, if you want to keep them, just don't raise the back of the car much with them. It stresses the shock cross member too much.
billdogg5
Ok thanks for the responses probably look into replacing them
billdogg5
You guys have any suggestions for replacement shocks?
Much appreciated
You'll likely find that your car will be sagging in the rear end once you remove the current shocks, and regular or even heavy duty shocks will not raise it back up. :alan2cents:
billdogg5
Whats the proper way to raise the her?
76orangewagon
Quote from: billdogg5 on September 04, 2021, 06:04:04 AM
I took mine to my local spring shop and had them re-arched to factory specs..they also would have gone more if I wanted more lift and the cost was much cheaper than buying a new pair from one of the aftermarket spring companies.
Mrbill426
With the mention of air shocks putting stress on the upper shock mounts is it advisable to install (pressurized) gas shocks back there??
I can compress a gas shock with my hands, so the spring is still doing the car lifting. Although a gas shock does increase ride height for a brief period.  So I don't think it is the same,  but interested in what others have to say.
Mrbill426
#11
@dodj me too.  I installed gas shocks on mine, had to do it by connecting the top first because otherwise lying under the car I could not pull them in to slide upper bolts through if I did the bottom first.  When I released the "tether" I had one shot at looping the bottom ends over the pins as they extended...there was no turning back  :o ... They are locked in there now... the rear is "solid".  I suppose they might relax over time.  :dunno:
Quote from: dodj on September 04, 2021, 08:24:59 AM
A high pressure nitrogen shock is around 160-200 psi. This psi is transferred through the shock in a controlled rate by the valving. By comparison, an air shock pumped up to 100 psi holding up 45% of a 3800# car,  takes an 855# beating in each shock every time the suspension cycles and the pressure is a constant that sits in the bladder and is not valved to transfer the pressure.
Get a decent shock QA1 , Bilstein .
KYB is Junk
76orangewagon
Here's what WILL eventually happen to your rear upper shock crossmember if you use air shocks to lift the rear of the car instead of of the springs.
