1970 Challenger SE - Massive restoration
Started by BAM, January 24, 2021, 03:36:39 AM
Solarguy and 1 Guest are viewing this topic.
BAM
So, I finally have the complete front end, complete rear suspension and complete front and back brakes. Paint job will be ready next week so early January we start assembling the K member, suspension, etc. Would you say is better to assemble the front on a bench and lift everything up from underneath the car, or install the K and everything else one by one?
Challenger in NC
#166
Quote from: BAM on December 21, 2021, 03:44:37 AM
I have never installed the engine/suspension assembly from underneath but that's the method I plan on using. You just have to rig up a lifting bar to the front end.
https://forum.e-bodies.org/engine-transmission-and-rear-end/4/engine-installation-methods/21292/msg263238#msg263238
Timbbuc2
I installed my k member and engine from the bottom,  it is so much easier. I made a frame to mount the assy on wheels so I could line it up. Then used my engine puller to raise the body.
Get in, I'll drive
Another vote here for putting the assembled K-member in from underneath.  I had the rear axle in when I did mine.   Instead of putting jack stands under the axle, I moved them forward a bit so the front end became easier to lift.   I used an engine lift and a lifting strap to pick up the front end, then rolled the engine and K-member under the car (it was on "piano dollies".... basically padded wood rectangles with caster wheels).  After lowering the front end and supporting it with jack stands, I used the engine lift, a floor jack and some blocks of wood to raise the K-member up and hold it in place so that the k-member bolts could be installed.
BAM
Sneak peak! One more coat of clear and some small bits and pieces left to be painted. I'll post again when the car is assembled and under the sun... AMAZING!
Challenger in NC
Beautiful color, you made a great choice.
Wow....go back to page one and look at the pictures....this is the most impressive build ever posted on this website  :alan2cents:
BAM
Wow! that means a lot coming from you @anlauto. I don't know if it's the most impressive but i'm sure is the most expensive 318 in the world right now  :haha:
BAM
Some more
cudamadd
Wow very very nice beautiful it's come a long way ,your hard work has paid off cheers  :australia:
BAM
And the engine started for the 1st time in over 30 years, after a full rebuild. It sounds healthy and strong.
https://youtube.com/shorts/_Tcho5mxLDU?feature=share
Quote from: BAM on January 10, 2022, 09:29:23 AM
That's very cool, but I don't think I would want to run the transmission dry like that for very long...wouldn't take much to heat-up that front seal  :alan2cents:
BAM
Guys,
anyone able to help me locate this green guides? Or maybe a complete replacement kit for all those plastic things? Summit is out of stock, YearOne ships them in 1-4 weeks which is normally 1-4 decades and I really need to get the windows on and get the car out of the paint shop.
