'70 Vert - waited long enough...
Started by Cuda416, September 09, 2020, 10:15:06 AM
Mr Cuda
#105
Well, blasting is a better surface prep than chemicals.
The pores of blasted metal hold the etch.. or iron oxide converter... (2 separate and completely different products) and make it hard to rinse.
Your rinsing blasted metal which is no good.  Remaining etch can leach through primer, and unrinsed rust converter can remain gummy.
Now you're chasing your monkey "tail"!
Cuda416
Quote from: Mr Cuda on March 02, 2022, 01:18:09 PM
Well, blasting is a better surface prep than chemicals.  The pores of the metal hold the etch.. or iron oxide converter... (2 separate and completely different products) and make it hard to rinse. Your rinsing blasted metal which is no good.  Remaining etch can leach through primer, and unrinsed rust converter can remain gummy.
Well I have a LOT to learn do this is all great info and I appreciate the it.
U.S.M.C. SFMF
70 Barracuda Vert
69 Dart Vert
65 Valiant
Mr Cuda
Because I have lived bodywork and paint so long, I have the habit of glossing over details like they are unimportant or well known.  If you have something specific that needs clarification,  just ask.
Cuda416
Quote from: Mr Cuda on March 02, 2022, 03:24:20 PM
I think everyone does that. I appreciate your offer, thanks!
U.S.M.C. SFMF
70 Barracuda Vert
69 Dart Vert
65 Valiant
RacerX
I was never able to find any viable blasters in the San Antonio area other than Dr. Blast
There were one or two others but they were more focused on industrial blasting and did
cars as a side thing.   Reviews were not very good and I think at least one of them closed
or stopped doing blasting.
If you ask that muscle rod shop in Boerne who they use they mention Dr. Blast
He is not fast or cheap but his work is good.    It has made my work much easier.
One thing to note is that any blaster is probably going to want it on a rotisserie so it
can spin to get at the hard to reach spots.
And I concur on the flash rust problem...   unprimed parts of my cuda (the swiss cheese
floor that was to be changed, for example) rusted almost instantly after the blasting.
I keep blasted parts in the air conditioned part of my shop so they don't rust before
I get a chance to protect them with primer or phospho.
Cuda416
I've reached out to him in the past, and I did  again this morning. Hopefully I'll get something arranged soon. I asked him about the carts he builds and not only did he answer, he made a video about it. Lol, service with a smile.
Hey, if (when) I bring the car to him, maybe I can swing by your place again and see how things are progressing.
-=C
U.S.M.C. SFMF
70 Barracuda Vert
69 Dart Vert
65 Valiant
RacerX
Quote from: Cuda416 on March 04, 2022, 08:50:53 AM
-=C
Yea I took my 15 inch rally wheels to him to be blasted and he made a special "lazy susan" jig to spin them around in the blast cabinet and made a video about that also.
No problem just let me know when you want to come by
Cuda416
Starting back on my car after some setbacks and distractions.
Got out in the shop to straighten out the inner cowl panels that were warped from what appeared to be a bad press.
U.S.M.C. SFMF
70 Barracuda Vert
69 Dart Vert
65 Valiant
larry4406
Where do those panels go?
Door jamb?
Cuda416
Quote from: larry4406 on December 14, 2024, 02:55:25 PMWhere do those panels go?
Door jamb?
Sorry for the late reply. Those are the inner cowl panel. They form a sandwich with the hinge pillar. The forward edge mates with the firewall.
U.S.M.C. SFMF
70 Barracuda Vert
69 Dart Vert
65 Valiant
Cuda416
After deciding the AMD parts were the better choice ( they seem thicker than the alternatives ) for a structural location, I bought the drivers side part and straightened it like the passenger side. You'd think that after several years of this same part stamping like crap they'd figure out it. Nope.....
U.S.M.C. SFMF
70 Barracuda Vert
69 Dart Vert
65 Valiant
Cuda416
Trying to get going again, had some things get in my way but they've passed now.
I'm looking for the height of two points of the frame rails and can't seem to find them.
1. Leaf spring shackle mounting hole from center to datum line
2. Height of the front-most bumper bracket bolt hole
Also, for the vert folks, the distance from the tip of the windshield frame to the top of the rear jam. I've measured 30" on both sides so I know they are the same, however I've seen the same measurement on a challenger vert at 29-1/2"
U.S.M.C. SFMF
70 Barracuda Vert
69 Dart Vert
65 Valiant
Cuda416
Finally making some real progress. Removed most of the floor, and trunk, left the transmission tunnel to act as a brace between the firewall and cross member. Outer rockers, like most of the car are completely shot but I'm hopeful for the inner rockers.
U.S.M.C. SFMF
70 Barracuda Vert
69 Dart Vert
65 Valiant
larry4406
Wow the tin worm was really busy on your vert!
Glad to see you back at it!
Cuda416
Quote from: larry4406 on May 09, 2025, 02:45:23 AMWow the tin worm was really busy on your vert!
Yeah that little bastard really did a number on this car. lol. It's good to be working on it again.
U.S.M.C. SFMF
70 Barracuda Vert
69 Dart Vert
65 Valiant
