avatar_Cudajason
Ahhh Crap!!!!! Bad lifter?
Started by Cudajason, June 02, 2019, 02:24:31 PM
Quote from: Chryco Psycho on June 05, 2019, 09:04:39 PM
Looks like the filter did its job  :twothumbsup:
the cams are Parkerized which helps keep the cam alive
Yeah it looks that way.  I will pull the pan and see what it looks like.
I spoke with Summit today and they are send me a new cam and lifters, no questions asked.
I just need to figure our what else I need to order and the get to it!
Quote from: jimynick on June 05, 2019, 08:31:51 PM
Jason, I think I have some Fel Pro head gaskets that I scored years ago- still in new condition- and if I can lay my hands on them, I'll give them to you to try to take some of the sting out of this. OK?  :cheers:
Thanks for the offer @jimynick Ian, I don't plan to pull the heads at this point, but if that changes I will let you know.
Wow that's nice of summit, didn't expect that!  :bradsthumb:
Gonna polish the lifter faces of the new ones?  :thinking:
Summit and Lunati are very good about the warranty.   They replaced my cam even tho i didn't follow their instructions of removing the Inner springs for break in.
Quote from: dodj on June 06, 2019, 02:21:41 PM
The article I put up here earlier, says they don't recommend polishing them.
Reason being, it's a slight hump on the face. You risk bringing that down by polishing.
Then it won't rotate.
To each his own...or be really careful if you do polish them.
Nope...not going to try that again. No idea if that contributed to the failure, but why tempt fate.
I tore it down tonight and found a second lifter that was bad. Its actually worse than the first one, but the lobe looks fine...go figure.
I am happy that Summit is replacing the cam.  They are even pay to ship the bad one back. I just have to drive to Niagara Falls, bout a 4 hour round trip to pick it up, and gaskets and oil etc and spend the time to redo everything.
check the oil pump , all of the metal went through it before the filter
Quote from: Chryco Psycho on June 07, 2019, 06:05:32 AM
@Chryco Psycho...that makes a lot of sense.
It was a bit of a pain to pull pan, but I did it.
I think I am in the clear!
The gear part looks really good, there are some slight scratches on the ring piece, but only slight.
The pan has some gunk in it, but it has not been off in 20 years.
Pulled the windage tray as well, just to make sure there was no crap sitting there.
Now to order gaskets etc. The cam is already sitting at my mail box in the US.
Awesome  !!
Looks like you got lucky , the brgs should be fine but I would still check a couple .
The real pain is getting the oil pan back on & sealed properly .
Put the Magnets on, Button up and go for it.
Door  number 1
It's either that, or pull it and do a total clean/rebuild
Door number 2
Dropping caps from under and checking...your choice.
Door number 3
Good Luck. Wanna see you going again.
Jason, Chryco is spot on with all his assessments.
Best of luck for speedy reassembly without issues.
Quote from: YellowThumper on June 08, 2019, 08:12:52 PM
I just gave choices, not recommendations. FWIW.
#72
Quote from: Topcat on June 08, 2019, 08:30:32 PM
Understood
FWIW on my end my statement was not against any of the many suggested offerings...
Mostly regarding notes the engine should be fine with just replacing cam and lifters.
My opinion on extra polishing lifters is a no. If original finish is prone to fail. Manufacturers would alter finish to correct issue.
One will never know difinatively. But seeing 2 bad lifters and only one cam lobe not bad is telling to me.
Opinion...
That was my feeling on the polishing as well, If it was a good idea, Comp, Lunati etc. would be doing it.
I'd REALLY suggest a hyd roller but you are in it this deep now ( replacement parts supplied) so......
