engine oil and zinc
Started by chal340, April 11, 2017, 01:20:44 PM
Jay Bee
This was recommended by my engine rebuilder: Shell Rotella T 15W40 and 1/2 bottle(6 onz) Comp Cams Break In Additive.
Spikedog08
Quote from: Jay Bee on April 12, 2017, 03:02:41 PM
I think for your first oil change for a new motor, that is a great combination  . . . But after breakin . . . I just want something effective and priced decent.   Many different choices out there . .
Quote from: chal340 on April 11, 2017, 01:20:44 PM
What brand of oil do you use for your engine, engine with flat tappet?
Do you add some ZDDP in your oil?
First of all are you talking oil for engine break in or just regular engine oil changes?  For break -in you definitely want to go with break in oil along with  comp cams break in oil additive.  After that, Mobil 1 15W50 like Cody recommended or Hemmings Classic car motor oil is what I recently bought.
bc3j
I've been using Gibbs Driven conventional oil from Summit.
https://m.summitracing.com/parts/jgr-02006
chal340
Quote from: usraptor on April 16, 2017, 11:56:15 AM
Yes, I speak about regular oil change.
For my engine I need 10 W40 and I found Amsoil in Europe.
http://www.amsoil.com/shop/by-product/motor-oil/gasoline/premium-protection-10w-40-synthetic-motor-oil/. This is an oil for Flat Tappet too.
It's not possible for me to buy some oil in United States, Summit. Jegs... don't ship oil, it's forbidden.
70 Dodge Challenger 340 A66.
Quote from: RUNCHARGER on April 12, 2017, 08:23:13 AM
And please, please do not start up a new engine like they do on T.V. Have fuel in the float bowls and fuel line, timing set correctly so it lights off in 1/4 turn. I cringe everytime these TV guys start up an engine with all the drama.
:iagree:  Grinding away at the starter, wiping lobes away as they go... Idiots... I haven't had to crank a new engine more than a couple turns in over thirty years... Do the work before you hit the key & expect it to be running practically immediately.....
So, is there a conclusion regarding an oil that will protect a flat tappet cam and that doesn't cost $12 a quart?  :popcorn:
chal340
For me, I'm going to use a specific oil for flat tappet with zinc and phosphore already inside and don't use an oil and add additives.
Like I read, oil company don't recommended to add "oil + additive" in their engine oils.
nsmall
I use this oil because it's reasonably priced and accessible in my town.  California has a lot of regulations.
Oriellys or Napa carries it.  Not sure if they ship oil.
Just one opinion....
Cudamike
Summit ships Brad Penn oil. I found a distributor in my area that sells for 80 a case.
nsmall
@chal340
@Cudamike
Are you happy with the Brad Penn as I've heard good things about it.
Thanks cudamike but @chal340 lives in France.  I was just trying to give another option.
Quote from: 1 Wild R/T on April 18, 2017, 12:44:29 PM
Exactly , not hard to get an engine to fire immedialty if you do all the prep first
Quote from: Cuda Cody on April 11, 2017, 02:03:47 PM
I use Mobil One full Synthetic 15w-50.  They make a Flat Tappet oil just for our old cars.
@Cuda Cody do you use this for break-in as well?  Do you add any break in additives?
No, I use special break in oil for engine break in periods then switch to the Mobil 1.
Quote from: Cudajason on May 09, 2019, 10:21:21 AM
Quote from: Brads70 on April 11, 2017, 07:30:48 PM
I have a hyd roller but still use Brad Penn 20w-50
Hey @Brads70 where do you find that stuff in Canada.  I found it on Amazon, but the price was crazy!
