Engine pad ID
Started by Mrbill426, October 15, 2017, 05:48:10 PM
Mrbill426
Can someone help me decipher this engine pad?  I know it is a 440, but what about the "B" and the 12   27?
Engine was assembled Dec 27th 1965....  B makes it a 1966 model year vehicle...
Mrbill426
Thanks!  :bigthumb:
Quote from: 1 Wild R/T on October 15, 2017, 05:58:43 PM
:iagree:
It should be a steel crank 10:1 compression approx 440 with the closed chamber heads , probably 516 casting
Mrbill426
Thanks!  I like this place  :bigthumb:
Quote from: Chryco Psycho on October 15, 2017, 06:05:51 PM
Mrbill426
RzeroB
Almost looks like a time capsule ... where was that thing hiding all these years before you found it??
Cheers!
Tom
Mrbill426
In a '66 Imperial Crown.  The 727 is odd in that the output yoke is "bolted" onto the output shaft with a through bolt, like a crank balancer on a crank.  I have never seen that before  :dunno:
Does anyone have any info on a '66 Torqueflite?   Is it "junk"?
:wrenching:
Quote from: RzeroB on October 15, 2017, 07:54:12 PM
Output / main shaft is different , should be able to use the rest with a different main shaft & possibly tailhousing on it
Mrbill426
Thanks!  Saving the combo for another future pipe-dream project I have a "shell" for; probably in a next life to be honest.  :thinking:
Quote from: Chryco Psycho on October 15, 2017, 08:07:48 PM
