LD340 install questions
Started by 73chalngr, May 02, 2020, 06:20:55 AM
73chalngr
Good clearance seem good. I tested it without the air cleaner first assuming the stud is the highest point then with air cleaner in place closed fine the only problem I see could be position of snorkel .
Scooter
Quote from: Mrbill426 on May 16, 2020, 09:35:23 AM
Looks great  :bigthumb:
How is the hood clearance?
Quote from: 73chalngr on May 16, 2020, 09:15:39 AM
I'd like to thank everyone for their input On putting my aluminum intake only a few minor things to clean up but it's running now no oil leaks sounds good I'm gonna go for a test drive later today
Looks good... is the LD340 considered a hi rise intake?
NO it is a mid rise dual plane , it is just slightly taller than the stock intake  :bigthumb:
Scooter
Quote from: Chryco Psycho on May 16, 2020, 09:59:04 AM
Thanks!
For decades it was rated as the top aftermarket intake for the small blocks , , The newer RPM is maybe slightly better & probably better in the higher RPM range
73chalngr
Yes I am from that decade.  Test drive went well.
Great , noticable improvement I assume  :bigthumb:
73chalngr
 It definitely sounded different didn't really do a whole lot wanted to drive it and come back and check it over again I think I may need to bring the carburetor up to speed now
For sure , the carb needs to be reset to match the air flow
RzeroB
The LD340 was my "go to" manifold for my 340 builds.
For bolts, I would use the ones with a small diameter 12-pt head on them - least amount of interference getting the in and easy to get a wrench on them to tighten them down.
Cheers!
Tom
I think an LD340 would love a 440 square-bore AVS too....
Otherwise I would expect to definitely have to upjet (or re-rod) with one.
Mrbill426
@73chalngr just curious... how did the manifold work out?
Quote from: 73chalngr on May 16, 2020, 12:12:02 PM
73chalngr
I have not driven the car a whole lot since the install I had other things to take care of around the house but I like the improvement . Intake bolts were a little bit of a pain in the ass.
