Never answered about coolant type/mix/percentage. Recovery system or just overflow. Radiator cap rating . These are all important questions if you are serious about diagnosing the problem.
If you can hear boiling in the system. it must be low on coolant/or air pocket in system. Pressure loss. And/or low on coolant % to distilled water.https://www.dewitts.com/blogs/news/13852841-what-pressure-cap-rating-should-i-use My back round is 40+ years of automotive service/repair. You need information to diagnose, especially since we are not there and just going by what you say.
The best you can expect are several educated guesses.
You need to do the testing, not just keep asking.
Diagnostics are a step by step process. Can take time and effort. And proper tools.
History... has this engine ever run cool or not since a recent change of a sort eg.. parts or adjustments. Everything is cause and effect.
If it was fine before, work back wards. engine driven fans are only efficient below 40 mph.
After that speed the fan does nil for cooling the radiator. Remember that the radiators job is to remove the heat from the coolant via heat "radiation" Like an electronic heat sink.
All cars with a/c have the condenser blocking radiator airflow.
You must solve the engines heart problem first before you go after the a/c. The a/c just points out the cars cooling system deficiencies.
It doesn't make the car run hot, it already did that and the fact that the temp does not go back down shows you your cooling system is inadequate for your engine/a/c combination.
Now when you get the engine hot, do you slow down to cool it off ? If so this is the opposite of what you need to do. Turn the a/c off and cruise around above 45 mph or get on the hi way or freeway To get more air flowing through the core and then it must cool down unless there is a blockage in the system.
Modern cars with larger engines generally run 2 electric fans. When you turn the a/c on most cars will have one of the fans immediately go on. This is because now you not only need to remove the heat from the cars cooling system but also the heat in the a/c condenser which is removing the heat from the refrigerant. They continue to work even when parked and shut off. You can hear cooling fans running in the parking lot in the summertime when every one is using their a/c. Since the engine is turned off the coolant is no longer flowing. This causes the engine to act as a heat sink and it gets hotter. The fans help keep the temp down in the radiator until the engine is started again. They run at a high speed that does not rely on engine rpms to work.
The cooling system was factory engineered for the stock engine and accessories. When ever you upgrade/modify the system, the rest of the system requires upgrading as well. Cause and effect again.
You have 2 separate cooling systems at work.
This is why when the radiators temperature rises, the transfer of heat from the radiator to the condenser makes the a/c less efficient and it will not blow as cool as it does when the engine is cool.
What degree thermostat do you have? A thermostat does not control temperature it is a thermo valve that opens and closes at a pre- determined temp. This just allows the coolant to now flow to the radiator. The coolant needs to be n the radiator long enough to have it's heat removed otherwise it will not cool down very much.
Putting in a 180° thermostat does not mean it will now run at that temp.
With todays fuels engines run hotter than 50 years ago when these cars were designed to run high octane/leaded fuel.
Contrary to what most people believe The higher the octane the slower the fuel burns.
That is why high octane tunes require more timing advance.
Regular fuel runs hotter than premium fuels do. That is the reason that running higher octane fuel in a car designed for regular show little return.
You may end up running hi-efficiency dual electric fans as part of your cooling system cure.
It probably needs to go to a cooling system specialist in your are to properly diagnose the situation and be able to do pressure testing and such.
And as far as the back in the seat comment, it was not a question of ignorance. Everything means something different everybody, follow ? Do you "get on it" for a few seconds ? Or on the freeway for a long time ? Or race the car. Anything you do in your driving style that is out of the "ordinary" places more load on the complete car. From the engine to the trans to the driveline , sus[pension, brake system etc.
I asked about whether it was an automatic and if so what stall of convertor is in it. This also affect engine temperature as well as transmission temp.
