Opinions..Will doing front disc brake conversion hurt value?
Started by GrandpaKevin, December 27, 2017, 01:21:22 PM
GrandpaKevin
I'm going to start buying parts to go through the entire brake system on my original 1971 R/T Challenger.
Car currently has it's 4 wheel manual drum brake setup which still works but is in need of a complete rebuild.
I plan to replace pretty much everything, master cylinder, all brake lines, wheel cylinders, shoes and spring kits.
Last year I did the exact same complete brake rebuild on the wife's original 4 wheel manual drum brake 1971 R/T Challenger but used a stock type front disc brake conversion kit and an aluminum master cylinder and A body distribution block from Dr. Diff.
I also went with Dot 5 brake fluid.
I wanted better brakes for the wife's car and didn't care if the master cylinder didn't look stock.
I am very pleased with the results.
My Challenger is a little more original than the wife's and I'm wondering if replacing the front drums with discs would drastically hurt the car's value.
My car is a 4 speed so much of the braking is done with the transmission and the drums seem to get the job done but
front discs would work better obviously.
So what's everyone's opinion for the brake rebuild, swap to front discs or keep and rebuild all the drums?
I still have the complete front drum brake setup off the wife's car sitting outside rusting away and would rather not have another drum setup sitting next to it so both will probably get scrapped. :thinking:
Thanks.
I would rather have disc brakes but I'm not much of a numbers matching sort of guy?
Depends on the collect ability of the car I would guess. Say a 1 of 1 Hemi Cuda I would guess the type of buyer for that car would want every nut and bolt original.
Spikedog08
Planning on selling the car?  If not, I would do it!   :takealook:
Racer57
I don't know anything as compared to some of the people here, but if all of the major components like the engine, tranny and differential are all original I would be hesitant.  If nothing else, swap it out and keep all the original components just in case.
RzeroB
Quote from: Racer57 on December 27, 2017, 01:59:19 PM
I agree ... but I wouldn't be hesitant. Brakes are one thing that can almost never be "too good" ... I want it to stop as well as it goes. Just keep all the original drum stuff in case you ever sell the car to a "purist" who would want to regress back to the original stuff.
Cheers!
Tom
71GranCoupe
As the 2 prior posts said, update, but save the parts.  :cheers:
Roadman
Quote from: RzeroB on December 27, 2017, 02:07:40 PM
                                 Yep     :iagree:
GrandpaKevin
Thanks for the replies.
I think I'm being a little too picky.
As far as originality the car has some of it's original FC7 paint but the entire paint needs redone.
Interior is all original.
Original engine is long gone with 440 installed now, 4 speed transmission is numbers matching's
Rear end has been swapped out for an original E body Dana 60, have the original 8 3/4 rear.
It might be for sale next summer but I think it's time for disc front brakes..... :wrenching:
Unless it's a numbers matching car, personally i'd want the better performance of the front discs.  If it didn't already have them; I'd put them on.
 :iagree:
Unless this is an ultra rare gold certified car I want the front discs on it
Keep the old parts and upgrade it. It's nothing that cannot be completely "un-done" over a weekend.
No question: Discs all the way. I did discs on my A-66 and used a stock type master cylinder, non power. It looked stock and stopped well. The front drums are easy to store complete if you like.
If you're hung up on originality you could always try upgraded drum brakes http://www.musclecarbrakes.com/stage3.html
I've installed two sets of these with good results.
I've had good results with the 11 inch drum cars I've had, they have stopped just fine. You have to adjust them once in awhile I find but it's no big deal. No question discs are better and if the engine is swapped anyway, no reason not to swap them.
My 66 Coronet and my 71 Charger were Hemi cars so I kept them original.
cbuczesk
This summer I replaced the front drums on my #s matching, 4-speed V-code Road Runner with original type discs so it looks stock. I kept all the original drum parts if I ever wanted to put it back. Nothing was cut or modified and it can easily be put back so I don't the value was hurt much at all.
Chuck
