Hydro Boost Project
Started by Cudajason, December 31, 2021, 07:48:13 AM
Dmod1974
You should have some free play between the MC piston and the hydroboost pushrod with the pedal all the way up.  With the engine off and the hydroboost accumulator discharged after pressing the brakes down several times you should be able to feel it by hand as you depress the pedal.  After the pedal take up there should be a period of lighter effort before the MC piston starts to move.  If not, you're diagnosis is right and the compensating ports are likely being blocked off or restricted.  I'd shoot for about 1/8" minimum to account for heat expansion and any unintended pump up in the assist unit.
Quote from: Dmod1974 on September 05, 2022, 06:58:48 PM
Yes sir that seems to have been my issue.  I spaced it out with some washers and the brakes are not dragging now.  nit sure it is totally fixed yet, the pedal is not always coming all the way back, but I will work on that.
Sure was nice to take the car for a spin!
Yea, but did you take your kid to school ?
Quote from: anlauto on September 06, 2022, 06:33:27 AM
sure did!  he was happy.
Quote from: Cudajason on September 06, 2022, 11:17:52 AM
Close call there with the kid. Glad that worked out for you.
Some good info here? Push rod depth gauge  and I noticed they recommend 1 1/8" MC for hydroboost?
https://baer.com/Remaster.html
Quote from: Brads70 on September 07, 2022, 12:08:13 PM
Oh cool a new tool!
I love that Bear MC, I was going to go that route, but damn its pricey
The Wilwood is a 1 1/8th bore, as Wilwood recommended.
I did some reading and the pedal return is common in new instals, might just need to drive it a bit and bleed the HB unit.
I will also rebleed the brakes and see what that does.
Quote from: Cudajason on September 07, 2022, 06:37:41 PM
Oh cool a new tool!
I mentioned this because in their video they said 0-.005" clearance  of the pushrod?
Maybe you will need a light spring to return the pedal?
Quote from: Brads70 on September 08, 2022, 05:51:31 AM
Oh cool a new tool!
INTERESTING!
I will try it with one washer instead of two and see if that helps.  of course I need to sort our my overheating issue first.
