avatar_gpm6367
1971 R/T 383 Engine Detailing
Started by gpm6367, October 08, 2020, 11:46:36 PM
Skdmark
-Harlan Ellison
:stayinlane:
gpm6367
I'm interested in the air cleaner. Can you message me pics? Good condition but needs refinishing. Was it a krinkle finish on air cleaner from factory?
gpm6367
How do those dates work on the coils? 3 digits?
gpm6367
Are these correct for my 71 383 R/T?
Skdmark
Black wrinkle on dual snorkel in 71.
3 digit date codes - first two are the week and third is last digit of the year.
Example: 131 = 13th week of 1971
If you want someone's attention then put an "@" in front of their name.
The board will message them.
Example @anlauto
-Harlan Ellison
:stayinlane:
Quite a few dual snorkle air cleaners were gloss black in 1971 including the 71 Challenger R/T I bought in 1979.
gpm6367
Is that choke and fuel pump correct?
Quote from: gpm6367 on October 26, 2020, 05:39:56 PM
The picture of the fuel pump look correct but you would have to make sure it has a 5/16" inlet. Some 440's and Hemi's use 3/8".
As for the choke, you would need to know the make and model number of the carb you have to insure you're getting the proper one.
gpm6367
#23
5/16 inlet and 3/8 outlet?
Is the OEM carb a 4160?
Let me know about the air cleaner.
Skdmark
For a stock 383 you want a Carter M4589 fuel pump.
It has nipples on inlet and outlet for 5/16 line.
440-4 HP and 440-6 uses a Carter M4845 fuel pump which has the threaded oulet that goes to a fuel separator.
The one in your picture looks like a M4845.
Either pump will physically bolt up and work on a 383, just different operating pressures.
The OEM Holley Carb on a 71 383 is a 4160 series.
-Harlan Ellison
:stayinlane:
gpm6367
Quote from: Skdmark on October 26, 2020, 08:16:02 PM
What I don't want to do is act without sufficient knowledge and replace correct parts. I saw the photograph and assumed I should have a threaded 3/8 line coming out of my fuel pump. I don't. I have a nipple on both inlet and outlet. Mine is a 71 383 and from what you're saying should have nipples on both? If that's the case it's not necessarily the wrong fuel pump.
If that is correct does a rubber line just come off the outlet at bottom of the fuel pump and bend upward to the fuel filter? As you can see a previous owner rigged a piece of bent steel line. The outlet comes out of the bottom and points at the ground. I'd love to see a picture of correct application with the 2 nipples.
It would appear than that the choke  is correct for my car.
gpm6367
So just to be clear the upper photo is not the correct set up for my 71 383 ?
In my opinion the top picture is correct for a 1971 383, but where you're going wrong is with the 3/8".  ALL 383 fuel lines are 5/16" so the pump would have 5/16" nipple inlet and 5/16" threaded outlet.
I'm trying to sell my air cleaner locally to avoid the hassles of shipping. Here's my ad:
https://www.kijiji.ca/v-engines-and-engine-parts/oakville-halton-region/1971-440-383-mopar-air-cleaner/1532056928
gpm6367
Ok, I see. The one pictured above is 3/8 out.
On the air cleaner how about $300 plus $25 for shipping?
Hook a brother up.  :)
