avatar_gpm6367
1971 R/T 383 Engine Detailing
Started by gpm6367, October 08, 2020, 11:46:36 PM
gpm6367
Who sells the gas filter?
Are the wire looms painted engine color?
A lot of vendors sell the filters, dated or Non-dated https://www.rosevillemoparts.com/product/fuel-filter-5_16-oe-non-date-coded/
Yes wire looms are painted engine colour on a big block typically, along with the PCV filter and the rubber grommets on the valve covers :alan2cents:
Another sample of why I don't like to ship stuff...It cost me $71.33 to send this air cleaner to Greg....that's just crazy... :o
gpm6367
gpm6367
Quote from: anlauto on October 28, 2020, 10:26:55 AM
I noticed the straps on valve covers for wire harness on pass side was painted and thought wrong.
The throttle cable bracket all painted?
So do i paint the plastic holder on metal loom also?
gpm6367
I have 2 different bolt heads on my thermostat housing.
Which is correct?
gpm6367
Battery cables come with a black plastic strap to presumably secure the positive cable? Where?
Quote from: gpm6367 on October 30, 2020, 07:09:24 PM
To the upper shock stud that protrudes through the shock tower.
I don't think either of the above bolts are correct for the thermostat, but if I had to choose I would pick the one on the right with no washer. :alan2cents:
gpm6367
Thanks .
Is this throttle spring bracket and correct?
Negative Battery cable goes under the bolt?
gpm6367
Thanks.
Coming along. Waiting for parts.
gpm6367
gpm6367
Why doesn't any of this stuff come with instructions?
Which fuel lines use the keystone clamps and how do you tighten them?
What is that metal bracket in the center of the set?
What about the PS pump? Keystone clamps too?
All the fuel lines use Keystone clamps.
There is a special tool to crimp them....I just use tile cutters.
The metal bracket is the fuel tank ground strap, clips on the sending unit and the main fuel line, over the rubber hose.
The PS hose uses the red squeeze clamps, which I don't see in your picture
