E-Brake
Started by dodj, March 12, 2019, 08:27:55 AM
I have no interest in the goofy original ebrake set-up where you basically string up a clothes line under the car.  :dunno:
So.....looking at e-brake options. Either the Lokar set-up or the estopp.
Any other non-factory suggestions appreciated.
Lokar
https://www.summitracing.com/int/parts/lok-xehb7000f/overview/
https://www.summitracing.com/int/parts/lok-ec-80fu/overview/
Anybody have experience with the Lokar setup? Pro or Con?
I installed an Estopp last year , mounted to the trans , never got to try it though as we never got the vehicle powered up before I left , seems like a slick unit , compact & you can hide the switch
What is that going to do for you? I had a handle like that on a T Bucket I built. You're still going to have to run something to either the wheels or mount something on the rear if you were eliminating going to the wheels.
ToxicWolf
I just have a little green push button in my console that engages and disengages the e-brake.
ledphoot
Where did you put the estopp unit? What modifications did you have to make to the factory ebrake cables? I am wanting to eliminate my factory ebrake pedal as well..
ToxicWolf
Quote from: ledphoot on March 12, 2019, 10:43:02 AM
Maybe these will help
ledphoot
Quote from: Rich G. on March 12, 2019, 09:34:19 AM
By mounting that handle between the seats, the e-brake cables will only travel down the tunnel above the d-shaft and out to each wheel. The clothes line will be eliminated. At least that is my thinking at the moment.
Quote from: ToxicWolf on March 12, 2019, 09:50:06 AM
Did the estopp come as a kit? Or do you have to purchase another companies brake cable, equalizer bar etc?
The Estopp still needed cables on the one I installed  :bigthumb:
392 Cuda
Has anyone tried the Lokar cable?
It looks nice installed on my 'cuda, but I don't seem to have a long enough throw on the brake pedal to engage the Wilwood e-brake.
I sell lots of Lokar and a few E-stops where I work. I prefer the stock stuff for my own cars....
I've installed the E-Stop before, it works good. :alan2cents:
I have a stock ebrake assy with a Lokar cable tying it to my Wilwood cable. Works just fine,
I didn't see a need to make it any more complicated or impact reliability with electronics.
#14
Quote from: GoodysGotaCuda on August 20, 2019, 08:47:07 AM
Never in my life have I heard an engineer say such a thing!
Where I work the engineers all go for more 'features'...lol
Car looks nice and clean Mike! Use the cut-outs to wake the neighbors occasionally?  :burnout:
