avatar_Yellow71Cuda
340 Connecting Rod small end bushing
Started by Yellow71Cuda, July 19, 2017, 01:34:17 PM
Yellow71Cuda
Machine shop checked my 340's connecting rod small ends (floating piston pin) and says all but one are fine.  That "one" has a bushing that seems "too loose" in the hole and the rod may have been machined too large from the factory (47 years ago?).   :notsure:
They are looking for an oversized bushing to install.
Thoughts?    :help:
lulurocks(Ken)
I can send you some free   rods  if you want , they came out of my 73 340 . . Was a good running   motor
Same part number , i dont know if they are the same  as 71
Yellow71Cuda
Quote from: lulurocks(Ken) on July 19, 2017, 02:22:20 PM
Wow...Thank you!  I will absolutely let you know once I hear back from my machine shop.   :thankyou:
lulurocks(Ken)
No problem  glad to help  let me know ill pm you my cell
Very nice of you Ken!
If that doesn't work out , I have machined rods before to install new bushings. They get honed to size afterwards. I'm sure any competent rebuild shop can handle this.
Yellow71Cuda
Quote from: Brads70 on July 19, 2017, 06:58:56 PM
So, in the case of the rod hole being too large, are there different size bushings available, or can the rod hole be knurled or something to allow for a tighter fit of the bushing?  :notsure: :thinking:
to my knowledge the bushing needs to be replaced  this should not be hard to find or do .
I believe only 2 years had floating pins though all other years were pressed pin
340challconvert
Classy thing to do.  Thank you for helping our hobby.
