Inherited Family Owned 1970 AAR - Limelight Build
Started by FIAARMN, April 23, 2020, 05:42:01 PM
FIAARMN
#105
carbs ordered.......
This weekend we will manually turn over the motor, get some oil in the cylinder, change the oil, drain fuel tank and do some interior work on the doors and panels. Need to get he drivers window fixed
Get some dash stuff together ......
1970 AAR Cuda Limelight Green,White Interior, - Hamtramck Built 36k miles, Verified All Numbers Match - Broadcast Sheet, Warranty Card & Window Sticker!
You'll be firing it soon. Having those carbs on will keep it the way your uncle had it.
It's kind of like waiting for Christmas morning after looking at the box's of presents for a week!  :yes:
FIAARMN
Quote from: RUNCHARGER on May 07, 2020, 07:29:09 AM
I agree, that is why it was decided to stay mechanical and to stay true to how he had it and what his plans where at the time of his passing.  If it is ever decided to restore it, it will be made right then.......   :burnout:
If you think doing a rest down the road is likely it might be a good idea to keep an eye out for a set of correct 4spd date coded carbs......
Though honestly the car will be more fun just as it is when you get it back on the road..... Restored means more stress if/when you take it out for a cruise....
Currently it'll turn plenty of heads & be a blast to take out for a drive....
Quote from: FIAARMN on May 07, 2020, 09:14:02 PM
I can appreciate that  :drinkingbud:
FIAARMN
did not get a chanve todo anything this weekend with the car.... We got side tracked with Mothers Day weekend stuff, oSat and Sun.....
Understandable , special weekend for almost everyone  :bigthumb:
FIAARMN
#114
Got an accurate broadcast sheet break down today!!!!! stoked
Learned a few things as well from the help of a very reputable and generous individual....
Just a couple things, nothing major........ not the original hood, but original spoiler, Not the original front fender, battery tray, carbs, radiator, master cylinder, dash (but a true AAR) Been repainted, 1995 (very well done, by a well known painter) under body has been coated, most likely when painted.......Car was a true daily driver....... Survivor with out a major restoration ........   Just happy to know a lot of history on the car, happy to know the car is documented correctly:
Numbers match, Block, Trans ect.. true and in the car
Have an original build sheet
Have original documentation (Dealer Paper Work)
Owner History
Original Manual
Scheduled Production Date 4/7/1970
Purchased 4/17/1970
Vehicle order Number - Ordered Car 132504
Hamtramck Plant, sequential number
Order Type- Sold Car (pigati chrysler vacaville)
FJ5 Lime Light
215 E Body 4 spd
X9 Interior White
C55 Front Seat Vinyl Buckets
A62 Rallye Instrument Cluster
And so On, nothing too rare or odd about the rest of the build sheet!
Now to start preparing the car for the carbs and to start up.... finish off the window repair to the track driver side and finish off the misc interior and dash stuff....... then drive it!
Little more detailed
1 – Broadcast Copy : Station # - Hamtramck
055564 – Sequence Number – Broadcast Print
407 – April 7th 1970 Scheduled Production Date
132504 – Vehicle Order Number – Ordered Car
BS  -  Car Line : Plymouth Cuda
23  -  Body Type : 2 Door Hardtop
J    -  Engine : 340 3-2 BBL  290hp V8
0    -  Model Year : 1970 F-Series
B   -  Assembly Plant : Hamtramck, MI
297483  -  Assembly Plant Sequential Number
Y05  -  Build To Spec's For : U.S.A. Order
Y14  -  Order Type – Sold Car
E55  -  340 3-2 BBL  290hp V8 A53 Package
D21  -  Transmission : A833 – 4 Speed Manual
D56  -  Axle Ratio : 3.55   w/8.75# Dia.
D91  -  Sure Grip
UO1  -  Tires : E60/G60x15 – F/R Polyglas GT
W34  - Collapsible Spare Tire  F78 x 14
H        - Trim Grade : High
   6     - Front Seat : Vinyl Buckets
     X9 – Interior : White
000   - Upper Door Frame Color : None
V01   - Paint Style : Mono – Tone
FJ5    - Body Paint : Lime Light
FJ5    - Roof Style : Lime Light
215   - E-Body  4Spd.  Trans  Floor Shift
X9     - Steering Column : Black
7000 – Steering : Power Ign Lamp : No
04 TT – Steering Wheel Type/Color :
               3 – Spoke / Woodgrain
02 X9 – Type/Color :
               Padded Horn Button / Black
2998974 – Radiator Dia. 26" STD  340  V8
3462193 – Radiator Inlet Hose : 26" 340 T/A
3438172 – Alternator : 37 AMP/Mono Pulley
2863216 – Fan : 7 – Blade/18.5" Diameter
2806070 – Fan Spacer : Torque Drive
2875320 – Battery Series/AMP/Caps : 24/59 Yellow
V6H    - Stripes/Body Side Moldings:
1944154 – Vac. Fitting : 1-Way P/Brake
148     - Engine Assy : 340 6bbl  w / 4Spd & Htr.
3577182 – Carb : Holley 2300  R4791A Center 2bbl
3410789 – Trans.A833 4 – Spd. Manual 23 Spline
2538935 – Speedo. Pinion : 35 Teeth/Orange
2883769 – Prop/Shaft : #7290 / 3.25" x 43.85"
076      - Axle Assy : 3.55 : 1 S/G  8.75" – 11"  Drums
71        - Road Wheels : 15 x 7.0"  Rallye
TX9      - Color : Black Painted Spare
81        - Spare : Collapsible   B.F. Goodrich
3461043 – Wh/Cover : 15" Trim Rings
3583052 – K-Frame : E-Body V8 Engine
2948723 – Ft. Sway Bar :  .94" Diameter
3400556 – Ft.  Shocks : Firm Ride
3400854 – Rr. Shocks : Firm Ride
59       - Front Brake :  Disc/Rr  Drum 11"
1857779 – Lt.  Torsion Bar : .90 x 41"  ALUM
1857778 – Rt.  Torsion Bar : .90 x 41"  ALUM
3400048 – Lt.  Rear Leaf Spring : TRANS AM
3400048 – Rt. Rear Leaf Spring : TRANS AM
  42  10    - Cl/Brk  Pdl : B51, D21,  Less J41
3577729 – Idle Label : 1000RPM in Neut. 2 ½ BTC
3402089 – Tire Label :  E60/G60  x  15"  Load Range
3466910 – Lt.  Exhaust : B – 340 T/A Engine Pipe
3466907 – Rt.  Exhaust : B – 340 T/A Engine Pipe
00       -  Lt. Tailpipe : Deleted w/A53 Pkg.
00       -  Rt. Tailpipe : Deleted w/A53 Pkg.
E P 7   -  Car Height : E Body – Power Strg-?
45       -  Master Cylinder : E Body/ Pwr Disc
14       -  14:00PM  Broadcast  Sheet Print Hour
12       -  #12  Broadcast Sheet Print Sequence Hour
A53    -   Trans Am Package – AAR Cuda
A62    -   Rallye Instrument Cluster
B42    -   Front Brakes : Disc/11" Rear Drum
C55    -   Front Seat : Buckets
C93    -   Carpets
F08    -   Trans Am Engine
STD    -   Alternator : 37 Amp
F23    -    Battery :       59 Amp
F96    -    Gauge :  Oil  Pressure
G11   -    Glass : All Windows Tinted Glass
G34   -     Mirror : Outside LH REM Painted
No     -     Mirror : Outside RH MAN Painted
G41   -     Mirror : Inside Day/Nite Rear View
H11   -     Heater :  With Defroster
No     -     Defogger : Rear Window Blower
No     -     Glove Box Lock
J15    -      Cigar Lighter
J21    -     Electric Clock
J25    -     Wipers : Variable Speed w/Electric Washers
J31    -      Horns Dual
No     -       Pedal Dress Up
J45    -      Hood Pins
No     -       Undercoating
J64    -       Instrument Panel Woodgrain
J82    -       Rear Spoiler  -  Trans Am
No     -        Lite : Map/Courtesy
No     -        Lite : Glove Box
No     -        Lite : Ash Receiver
No     -        Lite : Cargo/Trunk
No     -        Fender Turn Signal Indicators
No     -        Lamp : Ignition Switch w/Time Delay
No     -        Headlamp – On  Signal
No     -        Lamp : Seat Belt Unfastened
No     -        Lite : Title Switch w/Time Delay
L76    -        Lamp : Heater Controls
No     -        Mouldings : Door Edge
M21  -        Mouldings : Drip Rail
No     -        Mouldings : Body Sill
M27  -        Mouldings : Wheel lip Mouldings Delete
No     -        Mouldings : Body Belt
No     -        Front Bumper Gaurds
M83  -        Rear Bumper Gaurds
M88  -        Rear Deck Moulding Treatment
N44   -        Side Exit Exhaust System
No     -        Chrome Exhaust Tips
N65   -        Torque Drive fan
No     -        Maximum Cooling Package – Less Fan
N85   -        Tachometer
N94   -        Carb Fresh Air Package – Fiberglas Hood
N95   -        Evaporative Emission Control
No     -         Noise Reduction Package
No     -         Power Windows
R22   -         Radio : AM w/Stereo 8 Track Player
STD   -         Antenna : Telescopic Rear Quarter Mounted w/N94
S13   -          Front  Suspension : Rallye
S25   -          Shock Absorbers : Firm Ride
S31   -          Sway Bar : Front
STD   -          Sway Bar : Rear
S74   -           Steering : Power  Quick Ratio
S81   -           Steering Wheel : Woodgrain
STD   -          Wheel Covers : Trim Rings
W21  -          Road Wheels :  Rallye
18     -           Trans Am : Designates Trans Am Program Car
6bblgt
there is a '70 Broadcast Sheet Decoder here on-line  :takealook: under the "DECODER" tab
https://decoder.e-bodies.org/1970-mopar-build-sheet-broadcast-decoder/
a couple corrections/clarifications ......
1 – Broadcast Copy : Station # - Hamtramck assembly Line #1
     X9 – Interior : White (should show "XW")
215   - Steering Column: E-Body  4Spd.  Trans  Floor Shift
X9     - Steering Column: Black
7000 – Steering Column: Power Ign Lamp : No
                       the sheet actually shows 09 31 which represents 9:19 AM
FIAARMN
#116
Small typos, thanks for the assistance
H6XW
FIAARMN
plugs out, mystery oil soaking on the rings..... will turn over by hand next.....
Got some parts out of the boxes, ready to go back on the car.....
getting ready to install the front window trim!1!
FIAARMN
Any suggestions for the ash tray, found it in the box of parts.....
What paint kinda matches the interior dash stuff?... or leave it as is a put it in?
