Inherited Family Owned 1970 AAR - Limelight Build
Started by FIAARMN, April 23, 2020, 05:42:01 PM
Awesome that you found the original center carb for it !!  :bradsthumb:
FIAARMN
yes, you can say I was jumping up and down in joy that it was found and to know the center carb will be here soon......   :veryexcited:
1970 AAR Cuda Limelight Green,White Interior, - Hamtramck Built 36k miles, Verified All Numbers Match - Broadcast Sheet, Warranty Card & Window Sticker!
So what's the plan now, did you cancel the order you had for the other carbs ? Just going to go with the set your uncle had planned on ?
I'd start looking at cancelling those carbs, PayPal has a time limit, after that they won't help you... This guy has had way more that enough time to get you your carbs...
You advertise something for sale you damn well better be be ready to sell it... Not string the buyer along till PayPal won't do anything...
What a story!!! Thought I'd drop a note from the few Ebody guys in Calif.
I have a huge lot coming up for sale that I want to get rid of and you might be interested in some of it.
You staying in state or moving out?
FIAARMN
Dropped off the two outer carbs to a local builder.... he is rebuilding them...... Calling the custom carb builder we hired for the set (yet to have them)  promised 2 months, it has been 3..... Hope I can cancel if I do not hear good news tomorrow.
Hope to have it running by the end of the month!!!
FIAARMN
Ok, finally got to do some work today.....
1) Pulled Distributor and primed the pump for the 1st time
2) Pumped and emptied the fuel, very little in it
3) Put new Fuel Lines On
4) New Mechanical Fuel Pump
5) Picked up the carbs from the local builder who rebuilt the outer carbs
6) He checked the center carb (all is good) as you know we found it recently with rebuild paperwork
7) Added a battery. No brake Likes, All other lights work. Door Buzzer and dash lights good
I'll have a few questions after I post picks for all of you
Well, it appears the tank is rather new and been replaced.... there was maybe 1/4 of a gallon in the tank.
Then we added the new fuel pump...
After some other stuff got the dist off and shaft and gear out, primed the pump for the 1st time...
Good news, the oil pressure gauges came alive during priming
FIAARMN
So with the battery in........ Couple questions
Headlights, taillights work,,,,, cluster lights good, Door buzzer and dome light good.
Where do I start for the brake lights?
Next, see pic attached. These wires are not plugged into anything. Can you tell me where to start with them  or some of your thoughts, or if you know?
FIAARMN
Here is the pick of the rebuilt carbs......... just sitting on the intake.......  going to probably get them installed in the next couple of days, get the linkage hooked up and the fuel rail done.
Brakes a re fairly easy , power goes into the brake light switch [pink wire ] then into the turnsignal switch [white wire ]  then out to each taillight & out to individual taillights  dark brown & green IIRC , there is a plug behind the drivers kick panel to the rear that can be a problem also .
the wire behond the booster could be one of the reverse light wires 2 for 4 spd & 3 for auto , could also be the clutch start switch ground from the start relay .
Those two wires in your hand plug together, they are for the dash reverse light. The round tube connector by your thumb is for the road lamp wire :alan2cents:
Good progress, this should be firing up pretty quick.
FIAARMN
Got all new Bolts for the carbs......
Looking for a fuel rail now, anybody have a suggestion?
Looking to start it by Saturday!!!
