avatar_6Pack70
My AAR project
Started by 6Pack70, November 06, 2018, 03:34:28 PM
76orangewagon
Wow, fantastic work.
6Pack70
Thanks guys  :)  I won't have the engine done until late fall into winter Alan, and a good friend of mine would like to borrow those body dollies as soon as possible.   He's helped me out a ton, so I'll get the suspension on and get those dollies over to him.  I have the stand for the engine, trans, K frame and suspension but I'm ok with doing it the non-assembly line way.  Done it many times since the 80's with no problems.  Just gotta be careful.
Mymcodebee
Great detail work!!!  Keep pics coming!
Go weld up another set of dollies for your buddy and keep that baby on casters.  I'm heading to garage right now to build our third engine cradle. Just to easy to put the whole assemble in within 5 minutes.  👍👍
Great car!!
or just drop the K frame when the engine is ready to go in , faster & easier then putting it in from the top
6Pack70
I might actually do just that.  Only takes maybe an extra hour to set it up when I'm ready and slip it under the car.   :bigthumb:
If you plan to drop it later don't fully seat the ball joint tapers...
6Pack70
Excellent point... that would suck breaking those apart just to reinsatll them a half hour later lol.     Thanks for the tip.  :cheers:
If you're not moving the car around a lot, you can even put blocks of wood between the frame rail and the LCA and don't bother installing the torsion bars :alan2cents:
Quote from: 6Pack70 on May 05, 2019, 06:20:00 AM
It is seriously the best way to install it , you can have everything on the engine carbs , wiring , fan,  exhaust manifolds , no need to lean over the fenders , except to plug in wiring & attach throttle cable , far less chance of damage !
6Pack70
Definitely the right way and I'm going to just leave the front suspension snugged up. Not real tight at all. That way its off the body dollies.   Build the engine in the fall and put it on the fixture with the K frame and trans.  Then I'll lift the front up and slide the entire sub-assembly under.   :bigthumb:
Not to beat :deadhorse:
With all the discussions on many different forums that is the way to go safely.
I have zero help regarding everything I do on my car. In my head I can envision how it will work in stages all alone and safely.
6Pack70
Couple updated pics. Decided to just drop the engine in topside.    I know, I know...underneath is better.  In my case, its just gonna work out better for me next spring to install engine and trans topside.  Done it many times without incident.
Details look fantastic on this project  :drooling:
