project phantom
Cuda70-74
Quote from: JpRngr on November 14, 2019, 09:59:14 PM
So, are you using 4 identical bulbs with halo's or are you just using 2 halo's and 2 others? I've been trying to figure out UPIwhat I want for my high beams to go with my LED outters on my Challenger. It's funny turning on the high beams and they're a dim yellow, compared with the bright white of the low beams. I think im going to go with all 4 halo housing but im only going to wire 2 halos up tho.
Corey
1969 mustang
1968 charger
Cuda70-74
Little update. I installed my headlight but i had to modify the headlight retaining ring. I had to uninstall it and then use some expoxy where the spot welds were. I also got my kwik wiring harness(306$)and sound deadener. The American auto wire harness was way too expensive almost a (1000$ )
1969 mustang
1968 charger
@Cuda70-74 Were the hinges done by mopar-leo?
Cuda70-74
Quote from: JS29 on November 21, 2019, 02:34:45 PM
U notice and yes they were. Big thanks to Mopar-Leo 194$ total.
1969 mustang
1968 charger
Cuda70-74
Today I installed noico sound deadener and started laying out my wiring harness out.
1969 mustang
1968 charger
Cuda70-74
Today I made a bracket so I can mount my kwik wire fuse panel. I used the exitsing hole and drilled a hole thru the bracket I made. Im also wondering if anybody has a quater glass track slider mines broke apart and fell down into the quarter panel. Does anybody know what size gauges are in the dash?
1969 mustang
1968 charger
Cuda70-74
Thanks to Diyhemi.com im starting to make my own stand alone harness for gen 3 hemi swap. Its looks like a mess but im still labeling the wiring harness
1969 mustang
1968 charger
Cuda70-74
Quick question im rebuilding my heater box. Was just wondering does the fan need to be replaced. It seem to be in good condition??
1969 mustang
1968 charger
Why replace something that ant broke!  :alan2cents:
Cuda70-74
Quote from: JS29 on December 05, 2019, 06:13:49 AM
Thats usually my motto.
1969 mustang
1968 charger
Cuda70-74
My friend gave me a free 70 cuda driver door he had laying around for years. Since mines was hit in the reinforced it was pretty hard to repair. I also started rebuilding my heater blower box and waiting on my heater core. I also wanted to keep the factory markings so masked it off.
1969 mustang
1968 charger
Cuda70-74
Finally installed my heater box that I rebuilt and found the correct longer wheel studs
1969 mustang
1968 charger
Making good progress!  :clapping:   :popcorn:
Cuda70-74
1969 mustang
1968 charger
