ID Wiper motor
Started by soundcontrol, May 01, 2017, 11:34:25 AM
soundcontrol
Are theese wiper motors for e-body?
Looking at the wiring I'm guessing not, but what are the part numbers ?
soundcontrol
Quote from: anlauto on May 01, 2017, 11:35:40 AM
Don't know, I only have this picture.
Even if not correct, are they 2 or 3 speed, will they fit an e-body?
6bblgt
they are 3-speed - they will fit e-bodies but the (repositionable) top cover is clocked differently & may not park properly
the top one appears to be c-body or other??
the bottom one appears to be 2983033 early-'69 b-body
soundcontrol
Quote from: 6bblgt on May 01, 2017, 11:58:52 AM
Aha.Thanks!
Yup, you really need to get the numbers off the case.  1970 & 1971 end with "077"
soundcontrol
Quote from: Cuda Cody on May 01, 2017, 12:52:12 PM
Gonna check with the seller, he is selling both of them for 55 bucks, though it sounded like a good deal.
Even if B-Bodies that seems like a good deal.  Get the part number off of them and you'll know for sure what you have.
Timbbuc2
So a 3431077 would be for a 70-71? Thats the number on mine but it looks like the one in the picture.
Get in, I'll drive
The 1970 and 1971 3 speed wiper motors all look very similar.  But (like 6bblgt said) they are clocked differently and designed to run different linkage.  I think the restorers can reclock them when you have it restored so you can use it for whatever your applications.  Or re-clock it yourself.
Quote from: Timbbuc2 on May 01, 2017, 02:14:47 PM
Valkman
Is there a way to re clock them?
Yes, I think there is.  But I've never done it.  @Passion4Mopars  would probable know if it's something easy or if it's better left to someone with more experience then a beginning like me.
Quote from: Valkman on May 17, 2017, 04:18:36 PM
Passion4Mopars
Loosen the five screws on the switch plate and move the clocking nib to the correct position for the application you want to use, otherwise it will park in whatever position they are currently clocked for.
If there's a C body motor there, watch the bulkhead connector.  Looks exactly like an E body but it indexes on the opposite side.
 :clapping:   Thank you!!!!   :twothumbsup:
Quote from: Passion4Mopars on May 17, 2017, 04:45:24 PM
Valkman
So if it's parking to soon (not going all the way to the home position) which way should I rotate the cover?
