avatar_Cuda70-74
project phantom
Cuda70-74
#210
I finish building my little frame roller stands. Now I can roll her in and out of the garage.
1969 mustang
1968 charger
Cuda70-74
I finished the corner roof patch. It took 3 pieces of metal to make it but it came out good.
1969 mustang
1968 charger
Cuda70-74
Another update on the cuda. I'm fixing the sunroof patch it's going to take some time to get it right but the labor is free.
1969 mustang
1968 charger
Very impressed with your fabrication and welding skills.  Hats off to you.  :clapping: :worship: It's going to be really nice when you're done.  :bigthumb:
I admire/applaud your efforts on the roof but I have to wonder if at that point going to a new AMD roof would be a better option? I'd be worried after all your efforts you have a " oil canning" issue down the road when it's much harder/expensive to make right?  Big flat panels such as roof's , hood, and trunks I would not attempt to weld in patches. But I'm no expert in body work either.  :D
Cuda70-74
Quote from: Brads70 on June 13, 2018, 04:33:13 PM
Thanks. There is truth to what youre saying and since this is somewhat of a budget build
I found better use for the 500 plus dollars needed for a new roof. Trick the I did was I used thicker metal in the metal for support and I was even thinking putting a brace on under side of the roof to keep it ridgett.
1969 mustang
1968 charger
Cuda70-74
Picked up my 5.7 hemi today it was for 500 so I couldn't pass on it. I'll change all the gasket and clean it up.
1969 mustang
1968 charger
Planning on keeping the truck accessories and intake on it?
Cuda70-74
Quote from: GoodysGotaCuda on June 14, 2018, 05:44:57 PM
For right now unless there is a better option. I see u have a T56 magnum in yours is that the only manual tranny that will work?
1969 mustang
1968 charger
Quote from: Cuda70-74 on June 15, 2018, 09:09:56 AM
Anything from a factory 4spd to a magnum will work. Some assembly required.
Cuda70-74
Quote from: GoodysGotaCuda on June 15, 2018, 10:08:38 AM
With the 4 speed gas mileage wont be that good but the magnum cost an arm and a leg. Do u reccomend running the truck accessory?
1969 mustang
1968 charger
Quote from: Cuda70-74 on June 15, 2018, 03:03:44 PM
I run the car stuff because I feel it looks better aesthetically. Unfortunately everything on the timing cover would have to be swapped, alt, ac, water pump, etc.
If you're doing a metal patch the basic rule is:
Anything over a Nickel thickness of body filler and the panel either needs re work or replaced.   :alan2cents:
Cuda70-74
Quote from: Topcat on June 15, 2018, 06:58:55 PM
Very true but I wont  be using that much bondo.
1969 mustang
1968 charger
Cuda70-74
Quote from: GoodysGotaCuda on June 15, 2018, 05:59:15 PM
Thanks for the info. Some of those stuff I got to replace to anyways I'll just order the car version.
1969 mustang
1968 charger
