avatar_Cuda70-74
project phantom
Cuda70-74
Quote from: Brads70 on July 01, 2018, 11:05:59 AM
You sure are putting in the hard hours to make it work! :bravo:
Yes indeed
1969 mustang
1968 charger
Cuda70-74
Body work almost about done. Getting ready to shoot Epoxy Primer. I want to get the engine bay and front end of the car done so I can  assemble the front end.
1969 mustang
1968 charger
Quote from: Cuda70-74 on July 01, 2018, 09:47:49 AM
These are some good looking rear ends
Couldn't agree more!  Two of the best to come out of the '70s :twothumbsup:
Cuda70-74
Sprayed some expoxy primer today.I guess not bad for someone that hasn't painted a car in years. Got one area with some runs and missed a small area but still not a bad job. I'l fix those area it it again
1969 mustang
1968 charger
Nice process, looking good
Cuda70-74
Quote from: Katfish on July 11, 2018, 07:09:38 PM
Thanks. I'm just wondering how do u get paint in the fender braces?
1969 mustang
1968 charger
larry4406
Nice progress. What epoxy you spraying?
Cuda70-74
1969 mustang
1968 charger
Cuda70-74
Gen 3 hemi swaps are becoming popular now alot of car at the show had them. The paint job on the demon was 17k it was nice
1969 mustang
1968 charger
Cuda70-74
Went to buy a dent puller so I could fix the dents in the roof and the fender I dropped.The is from harbor freight and it works pretty good.
1969 mustang
1968 charger
soundcontrol
Quote from: Cuda70-74 on July 11, 2018, 07:36:19 PM
I painted mine on the inside before I welded them in, I just need to get some on the back of the welds now.
You can always use Eastwoods Internal Frame coating, works well inside stuff you can't reach with a regular spray gun.
Cuda70-74
Quote from: soundcontrol on July 16, 2018, 02:46:08 PM
Thanks I'm going to try that
1969 mustang
1968 charger
Cuda70-74
Well I found a car intake manifold for a 100 buckets off craigslist which I'm going to install. If youre going to install a car intake manifold on a truck engine be advise your going to have to change the timing also plus reroute the map sensor wires. I'll update if there is anything u will have change. I also took the cylinder heads off alot of carbon build. I'm going to clean the top of cylinder heads and send the heads of to a machine shop.
1969 mustang
1968 charger
Cuda70-74
The last piece of sheet metal that needs to be replaced came in today. I also took out the rear floor pan and the timing cover suppose no slipping in the timing change.
1969 mustang
1968 charger
Great progress!
Intake looks nice, I'm following along.  Really curious what all the differences are between the truck and car Gen3 motors.
